> Tens Source
Posted: September 02, 2012 07:52 am
Been contemplating it on and off for a while, breadboarded a little thing this weekend.
Note, this circuit produces waveforms typical of some TENS applications, but I in no way endorse its use as a medical device.
Schematic:
http://t3sl4.dnsdynamic.net/Images/TENS_Supply.png
If I were to make a device based on this, I think I would include the HV supply in the design (right now, I'm using this one), and run it from batteries or a medical grade source. I'd also add ESD protection on the input (reverse protection diode, input filter, TVS) and output (UF4007s, from GND, to each output, to +HV, and a TVS or MOV on the HV rail to catch overcharge).
Posted: September 02, 2012 09:41 am
Hi Tim,
I have a TENS machine and it uses isolation transformers in the outputs, even for battery useage. Perhaps for safety?
Cheers!
Posted: September 02, 2012 10:35 pm
Not a bad idea... could easily add a small ferrite cored transformer, probably a couple hundred turns would do it. Could also avoid the HV supply if you use a step-up. Leakage and saturation limit what you can do with the waveform, but it may not be a problem, depending on just what waveforms are required.
Posted: September 02, 2012 10:44 pm
They are really tiny. Reminded me of the IST's in late 70's/early 80's transistor radios.
The cores may be ferrite, as I can feel the heckuva sharp rise/fall time blink.gif
Posted: September 03, 2012 01:25 am
yep ... drive an isolation type transformer .
this keeps the hv "on the other side" and provides additional safety .
some off those tens units i have messed with provide "multiple strike" pulses .
5 Hz seemed to be common .
some of the units did a ramp up/ramp down multiple strike .
i do not imagine that the waveform is super critical .
Posted: September 03, 2012 01:33 am
Far as I know, it's more about energy delivery, and keeping the voltage high enough to stimulate things.
Holding your fingers on the output of the above circuit, you can feel a tingle with the current control knob at about 10%, but on a larger, sweatier part of the body, like the arm, you can't feel much until 50 or 70% up. I think current density is the important part, which means lots more current is required, at about the same voltage or lower, for larger pads or greater separation.
telomere
Posted: September 03, 2012 04:01 am
Just an FYI for the TENS users. Don't put the leads on opposite sides of your head.
Don't ask my how I know that.
"Sometimes I can't tell the difference between thinking and being quiet, but I'll try."
Posted: September 03, 2012 10:56 am
heh heh heh ... oooohhh , i smell a good story here !
"hey ! hold my soda and watch this !!"
Posted: September 03, 2012 11:29 am
I also read somewhere that excessive use (>20 mins at a time) can cause clots.
Perhaps someone heard of it too? Is this still holding or debunked?
Posted: September 03, 2012 11:00 pm
QUOTE (Geek @ September 03, 2012 05:29 am)
Never heard of it, and can't imagine why it would (not directly anyway). Perhaps being immobile for long periods (a known cause of clots) while using a TENS? dunno.gif
I have heard of nerve damage being a possibility with some of the home-made units though. beer.gif
[EDIT] FWIW...
My TENS unit (XFT-320) max output specs are 100V, 20mA, and 1-101 Hz. It also has different pulse pattern options (power/freq cycling, etc.).
However, the power ratings are either exaggerated, or else the pulse duty-cycle is pretty low. Testing with 67VAC (60Hz) at 16mA feels much more powerful than the TENS unit's highest setting.
