| yero |
Posted: April 16, 2012 02:54 am
Newbie ![]() Group: Members+ Posts: 3 Member No.: 36,650 Joined: April 11, 2012 |
I have two of the olson tube side-bander ham unit. I want to use the chassis and big power transformer to build a tube amp. the power supply uses a vibrator. Is the transformer HV or does the vibrator generate the HV B+ yero
Posted: April 16, 2012 04:33 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 3,295 Member No.: 181 Joined: October 05, 2002 |
The vibrator produces a chopped DC,which is fed to the transformer,and you get the HV out of the secondary side.
Be sure to check/replace the noise filtering caps and choke(s) around the vibrator circuit,or you may end up with a very noisy supply. Here's some links/info: http://radioremembered.org/vpwrsup.htm http://cool386.tripod.com/vibservice/vibservice.html http://www.slideshare.net/ionela13/vibrato...r-supply-design http://www.electronixandmore.com/articles/...upplies.html#11 -------------------- "we need an e-kick-in-the-nuts button" -Colt45
Posted: April 16, 2012 04:39 am
![]() Moderator Group: Moderators Posts: 8,912 Member No.: 62 Joined: July 23, 2002 |
The cap across the vibrator contacts is critical too... like on a set of old breaker points, if it's kaput, your contacts will soon be as well and efficiency will be hideously low.
Cheers! -------------------- -= Gregg =-
Posted: April 16, 2012 02:01 pm
yep ... the "buffer caps" .
the power transformer may have dual voltage capabilities ... there is a 110 winding and a "mobile" vibrator driven winding (might be switchable between 6 and 12 volt) . a schematic of the units is the absolute best way to know exactly what is going on . what kind of amplifier are you building ? -------------------- "Know how to solve every problem that has been solved"
| yero |
Posted: April 19, 2012 03:52 pm
an audio power amp. was hoping to utilize parts from the sidebander. I can't find a schematic. there may be a usable inductor or output transformer? The case (chassis) may be all that I can salvage. any suggestions?
Posted: April 20, 2012 12:40 am
you might be better off selling the radios on ebay and then using that money to buy parts .
with the age of those radios ... the parts in them are a might bit "iffy" . say , a resistor that has changed value or a leaky (electrically) coupling cap ... this can cause all sorts of problems and trying to find it is difficult . there is nothing like building a problem into something . -------------------- "Know how to solve every problem that has been solved"
