| Skeith |
Posted: March 15, 2012 05:50 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 4,094 Member No.: 2,695 Joined: June 13, 2005 |
I was wondering, How many watts of RF would a typical variable cap from an old AA5 radio or similar be able to handle?
I am working on experimenting with a magnetic loop antenna and am trying to select a capacitor to tune it. -------------------- -Barrett
Posted: March 15, 2012 06:11 am
![]() Moderator Group: Moderators Posts: 8,902 Member No.: 62 Joined: July 23, 2002 |
Caps are rated in volts, not watts.
At resonance, E=I*Z. Off resonance, reactances come into play and things get complex real quick. If you're talking magnetic loop, those hare nasty hard on caps, as the smaller the loop, the higher the voltage. A 160M loop that can fit on a city lot can easily see a good 10KV across the cap before you come near legal power. With larger loops, they start to carry lotsa current and less voltage. Seems all my bookmarks for magnetic loop calculators are now bad Cheers! -------------------- -= Gregg =-
| Colt45 |
Posted: March 15, 2012 07:31 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 3,747 Member No.: 1,333 Joined: October 02, 2004 |
The voltage is about the air spacing on them - which is why bigazz RF amp stuff has 3/8" airgap between the plates, instead of 1/16"...
Anyway, on AA5's they're usually in areas with almost no bias and not much RF either, hell, the whole sets run on 100V... although I'd still think they're probably good for 500V? I don't know. At least in the desert where we live, maybe not in sub-tropical cascadia Keep in mind the trim/padding caps on the side might not have the same umpfh, and also make sure you don't have the shaft hot, unless you've got a good insulated knob for it.. I'm thinking of 40's octal sets too, late run mini tube ones with PC boards shrunk the caps down somewhat.. I got a big honking one at the local surplus joint, I can check if they have some more sometime... -------------------- >]:::|-
Posted: March 15, 2012 11:34 am
Indeed! 50% derating for 100% humidity 10 months of the year. -------------------- -= Gregg =-
Posted: March 15, 2012 02:33 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 19,515 Member No.: 15,154 Joined: May 15, 2008 |
yep ... normally the major concern is breakdown voltage .
there are cases where dissipation is/can be a factor ... tuning the tank circuit in a decent sized output rf final or the ATU for a high powered transmitter . -------------------- "Know how to solve every problem that has been solved"
Posted: March 15, 2012 02:58 pm
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 12,951 Member No.: 5,314 Joined: June 04, 2006 |
You can submerge it in mineral oil and increase both voltage and capacitance.
"A 100 to 365pF variable capacitor with a 1KvDC breakdown voltage (i.e. a plate spacing of 1mm) becomes a 270- to 985pF unit wit 7500 VDC breakdown rating." From this page: http://www.sentex.ca/~mec1995/circ/hv/hvcap/hvcap.html -------------------- Mac *
Posted: March 15, 2012 04:19 pm
![]() Forum Addict ++ Group: Moderators Posts: 18,143 Member No.: 73 Joined: July 24, 2002 |
I think the average radio size cap is 500 or 1000V rated. Should be able to put more than a few amps through them, which translates not to real power, but to reactive power. I mean, you can see the whole thing and it's all metal, so there should be no problem sinking 20A or more through one -- that's a good 10kVAR right there, but you probably can't even push it to melting because the capacitance is small, so the frequency would be high, and parasitic inductance would become an issue (the rotor mounts themselves would have notable inductance at low UHF where you'd actually be able to draw that much current through the capacitance!).
Tim -------------------- Answering questions is a tricky subject to practice. Not due to the difficulty of formulating or locating answers, but due to the human inability of asking the right questions; a skill that, were one to possess, would put them in the "answering" category.
Posted: March 15, 2012 10:20 pm
AA5 caps were the 'load' cap of choice for the little 120W CB linear amps I used to make. Single sweep tube, ~700VDC B+, 52Ω output impedance.
So, yeah, figure on 750-1000 volts, for a typical cap with ~.020" plate gap. -------------------- Trouble rather the tiger in his lair, than the sage among his books.
