| wai-tn |
Posted: January 14, 2012 11:35 pm
Newbie ![]() ![]() Group: Members+ Posts: 11 Member No.: 36,379 Joined: January 14, 2012 |
Dear members,
I programmed a tool with python and I would like to know if it is implementable on a mobile system with very reduced capacity calculations. This requires an expertise in electronic or digital circuits which is beyond my skills :/ Problem: Making a shift on an input vector from a specific address with a delta offset. Example: Rot(@2, 3) : delta = 3 offset from the address @2 of the vector. All the other fields have to remain unchanged in the output. Question: Can I express this type of partial right/left register shifter/rotator via a set of combinational logic gates? This should consume how many logic gates if I have 54 entries and the representation of data is = to 6 bits. Reminder: in a classical design, a LFSR, performs a shift on a vector, but this will affect the entire output vector. (What I want to do is a partial shift or rotation.) Thank you in advance for your help. Your help allows me to know if what I do is helpul for the scientific community, or if I have to move on Looking forward to hear from you soon. Wai This post has been edited by wai-tn on February 16, 2012 11:03 pm |
| damien |
Posted: January 14, 2012 11:54 pm
![]() Forum Addict ++ Group: Moderators Posts: 5,051 Member No.: 175 Joined: October 02, 2002 |
In future, do not post the same question three times across different
aspects of the board. We are very active here and most read new posts. I've deleted two of them. Damien -------------------- Wow you look quite normal for a geek.
The statistics on sanity are that one out of every four persons is suffering from some sort of mental illness. Think of your three best friends -- if they're okay, then it's you. |
| wai-tn |
Posted: January 15, 2012 12:00 am
I'm sorry for this
I didn't know in what topic my question matches the best! |
| millwood |
Posted: January 15, 2012 02:35 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 1,823 Member No.: 25,377 Joined: July 26, 2009 |
something like that would be quite simple to implement on a mcu or a fpga/gate-based system, assuming we are dealing with integers.
if floaters are involved, it can be quite difficult. |
| wai-tn |
Posted: January 15, 2012 09:59 am
thank you Millwood for your response. Only integers are involved in my design.
If you may, further explanation will be welcome, as I m not a specialist in the domain mcu or fpga/gate-based system can consume only some hundred of gates with 6 bits output? because the environment of use is very constrained and I have to optimize as much as possible. is this an example of circuit to implement? http://en.wikipedia.org/wiki/File:FPGA_cell_example.png thanks for your interest! have a nice day! |
| millwood |
Posted: January 15, 2012 02:14 pm
i am not familiar with fpga enough to tell you if that's schematic is correct.
i can see that implementing in mcu is a piece of cake - simply adding a number to an axis of a vector. you can get simpler than that. a fully hardware based solution might be the use of memory chips where the address line carries the incoming vector and the adder and the data line carries out the result. |
| GPG |
Posted: January 16, 2012 03:23 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 6,166 Member No.: 792 Joined: April 25, 2004 |
Look up barrel shifter, eg
http://en.wikipedia.org/wiki/Barrel_shifter Many more results available. Not sure if this is what you want, since the overflow goes to the LSB. |
| wai-tn |
Posted: January 16, 2012 12:54 pm
thanks GPG,
In the example seen in wikipedia, the order of the entries remains the same : ABCD as DABC, CDAB, or BCDA While I have to realize a shifter doing: ABCD --> ACDB -->ACBD -> thus, in the output we see only B (or a sequel of entries) moving. Do the barrel shifter make a partial shift like below or we have to add other calculations? Why did you think that the overflow goas to the Least Significant Bit ? Thank you for your reactivity.. any new idea makes the problem easier ! Have a nice day! |
| GPG |
Posted: January 16, 2012 01:20 pm
Was thinking shift up. Of course the underflow (shift down) will go to MSB, it's the nature of a barrel shifter. You don't shift the bits so much as 'rotate' them.
No a barrel shifter will not do this unless ACD are "don't care" values. But you have made the problem clearer.
| millwood |
Posted: January 16, 2012 10:53 pm
that's different from what you described earlier but that's not difficult to do either. |
| wai-tn |
Posted: January 16, 2012 11:20 pm
Good news, if the problem is not difficult neither!
In my last message I described the problem using the same example cited in the link sent by GPG.. May be I had to use an expressive example from the beginning! What I want to do is a rotation/shift for one entry without touching the other entries: ABCDEFG --> Rot(@2,3) : means rotate (or shift) the content of the adress @2 which is equal to B with three steps at right. ACDEBFG , is the expected output. another example: ABCDEFG --> Rot(@6,3): means rotate the content of the adress @6 which is equal to F with three steps at right. ABFCDEG is the expected output. Thank you for your understanding! I am looking forward to know the solution! |
| millwood |
Posted: January 17, 2012 12:15 am
assuming A,B,..G are bits.
rot_r1(dat, n) shifts the nth bit of dat right by 1. for now, assume n <>0 - we will consider that later. rot_ra(dat, n) { tmp = dat & ~((1<<n) | (1<< (n-1)); //clear dat's nth and (n-1)th bits tmp_n = dat & (1<<n); //nth bit tmp_n1= dat & (1<<(n-1)); //n-1th bit return tmp | (tmp_n >> 1) | (tmp_n1 << 1); } if n = 0 (the right most bit), you simply shift everything to the right by 1 and fill the msb with the then-lsb. |
| millwood |
Posted: January 17, 2012 12:17 am
to right shift a bit multiple times, you simply call the above routine multiple times.
for example to shift the nth bit 5 times, dat = rot_r1(dat, n); //shift the nth bit by 1. n>=5; dat = rot_r1(dat, n-1); //shift the n-1th bit by 1. dat = rot_r1(dat, n-2); dat = rot_r1(dat, n-3); dat = rot_r1(dat, n-4); the above isn't optimized but it should get you started. |
| wai-tn |
Posted: February 16, 2012 02:04 am
thank you.
