> Comparator + Constant Current With Tl431, an optimization challenge
fenugrec
Posted: November 25, 2011 06:24 am
Hi all,
I feel what I'm trying to do can be pretty simple, but I just can't figure it out. In short : some equipment runs either from battery or AC power. I want a power LED to light with a constant (say +- 10%) current, but it should turn off when the battery voltage drops below a certain threshold.
I don't have room for a comparator IC, and there's no regulated supply in the circuit.
I figure a good start is a TL431 "programmable" shunt regulator (TL431 datasheet). Making the TL431 work as a constant current source is easy; the low voltage threshold is also straightforward. Making a single TL431 do both is a challenge... I'm sure there's a way to do it simply, but I haven't found the miracle circuit yet. I think I'll have no choice but to add at least a transistor and some diodes... hopefully someone here can do better !
Rough specs:
The V+ rail is about 6-9V when powered by the battery, otherwise 9-13V. Low battery threshold : 7.5V.
The first circuit that comes to mind (and works) is
Does anyone see how to improve this ?
Posted: November 25, 2011 08:01 am
QUOTE (fenugrec @ November 24, 2011 11:24 pm)
Why not just power the LED straight thru a zener of the appropriate voltage (and wattage)? Voltage drops below that level, zener stops conducting, LED goes off. beer.gif
Posted: November 25, 2011 09:01 am
If you don't have room for a comparator, you won't have room for a TL431, transistor and more than two resistors. For that matter, you hardly have room for resistors, if you consider there are comparators in SMT packages under 2mm square.
How sharp should the low battery threshold be, and what range of voltage should be tolerated for that 10% change in current? If both specs are quite loose, a zener will suffice -- the turn-off curve is exponential rather than piecewise linear or hysteretic, so it will dim out very slowly as the battery discharges.
If you want close to ideal performance, it would be very easy to create a circuit which does it in, say, 20 transistors or so, but good luck fabricating the IC to fit it in the small space...
Posted: November 25, 2011 09:36 am
You didn't mention your voltage range. Preset 3-pin voltage detector IC's could be one option. They're most commonly available in the 1.5-5V range.
Space = down to SOT-23. It requires fewer connections than a comparator and doesn't need a supply voltage higher than the input = much smaller. Power and voltage input are one and the same, ground, output pin. Output pin can drive an LED, directly. Just need a series resistor.
millwood
Posted: November 25, 2011 12:58 pm
you can get a constant current source out of a jfet;
you can get a voltage sensor out of a pot or a resistive divider;
you can get a pretty good comparator out of a npn, mosfet, or even a tl431.
so you can build a much simpler design than you have, out of the components mentioned above.
fenugrec
Posted: November 25, 2011 08:49 pm
Interesting - not quite the type of replies I expected... I omitted some important details in the original post!
As V+ increases above threshold, so will current. Unless I use the zener as a shunt regulator, which in my tests really didn't have a steep enough response... and it would end up looking like a non-adjustable TL431 circuit anyway.
About the "no room for a comparator" - as I forgot to mention, I'm not laying out a new PCB, I'm patching an existing circuit. I know they make comparators in SOT23-6, but I don't have any on hand. Besides, a comparator can't also regulate LED current - I would still need some other active component.
I can find pads for a TO-92. 0603 resistors fit everywhere; I also have some SOT23 transistors that are easily soldered in place. Much easier than trying to layout 8 SOIC or TSSOP pins in mid-air... that's more what I meant by "no room".
That's probably the simplest solution. I would just need to find a jfet that has a reasonable Idss.
Thanks a lot for the ideas, guys.
This post has been edited by fenugrec on November 25, 2011 08:50 pm
Posted: November 26, 2011 12:42 am
QUOTE (fenugrec @ November 25, 2011 01:49 pm)
A series resistor for the LED/zener would be required anyway. Current could be safely limited at max V and the LED would still be "on" several volts lower.
You would also have to allow for the LED's forward drop when choosing zener voltage btw (a moot point if you're using a different method). beer.gif
Posted: November 27, 2011 12:03 am
Come to think of it, you might be able to trick a TLV431 into PWMing the LED in such a way that it maintains reasonably constant current above the threshold. It will probably keep osc
Come to think of it, you might be able to trick a TLV431 into PWMing the LED in such a way that it maintains reasonably constant current above the threshold. It will probably keep oscillating for a few fractions of a volt below threshold though. If hysteresis is acceptable, and the amount can be controlled by design, this would be fine.
