| Chantry |
Posted: February 17, 2011 09:37 pm
Jr. Member ![]() ![]() ![]() Group: Trusted Members Posts: 60 Member No.: 30,155 Joined: July 27, 2010 |
Hi
To start off, im a product designer by trade so im sorry if this question is reminiscent of GCSE physics. My project needs to rotate a large but reletavly free moving shaft (about 2in diameter) with temperature. I would like to achieve around 15degrees of rotation with a heat range of around 200 degrees (60-260C). This is for a third world environment so I cant use exotic materials. My idea is to wind a strip of material around the shaft and fit it to a stationary block. The heat will cause the material to expand, and will cause the shaft to rotate. The more windings I have around the shaft, the more rotation I can expect to achieve. Does all of this sound plausible? Is a material like copper the best for this purpose, or something like aluminium? How do I work out the expansion of a metal with heat? Thank you! James |
Posted: February 17, 2011 11:10 pm
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 12,956 Member No.: 5,314 Joined: June 04, 2006 |
Are you aware that applications of this type (thermometers, thermostats, etc.) are generally made from bi-metal strips (two metals with different expansion rates) in order to achieve the desired rotational movement?
Not sure how well (or if) a single metal will work for this, as the coil may just expand in diameter. Perhaps some of the other members will comment. -------------------- Mac *
| ChipUser |
Posted: February 17, 2011 11:15 pm
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 2,373 Member No.: 15,445 Joined: May 30, 2008 |
Take a look at the properties of Nitinol wire. It may sound exotic but you won't need much to do what you want. It is also known as Flexinol (I think that's a trade name).
| Chantry |
Posted: February 18, 2011 12:51 am
Both bi-metals and Nitinol are both very helpful leads, thank you.
Posted: February 18, 2011 07:30 pm
A bimetal strip can be made by simply riveting two strips of different metals together. A little research will show you which of the common metals would be the most suitable.
BTW: A single metal strip won't work, as any motion will be microscopic. -------------------- Trouble rather the tiger in his lair, than the sage among his books.
