Posted: February 09, 2010 12:38 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 12,937 Member No.: 15,154 Joined: May 15, 2008 |
about a week ago the coffee make started spewing water all over the counter and sounded like it had ingested some of my chili and jerky .
i pulled the bottom plate off and found that the aluminum casting that contains the boiler tube and heating element ("U" shaped) had developed a stress crack of the inner center of the radius in the area between the two cast-in channels . i have fixed this POS-1 twice before but for different problems . not being one to give up easily (my gf has a different thoughts about this characteristic) , i went looking for my stick aluminum solder ... alas , it was not to be found . a trip to the hardware store proved fruitful ... about 30 minutes after arriving back home the coffee maker was purring right along . i filled in the radius area and also the straight portions (out to 1.5") . let's see that crack out now ! the package says that it contains Al and Si ... hmmm ... it had a tube of a liquid "halogen flux" (fluorine ?) , the stuff works better than the stick solder i have *somewhere* . |
Posted: February 09, 2010 12:58 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Cleanup Taskforce Posts: 22,696 Member No.: 5,746 Joined: July 24, 2006 |
Fluorides are a common ingredient in specialty brazing fluxes.
If I had known, I have several of those heat plates hanging around, including one that I welded sidewalls to, in order to use it as a solder pot. I can send you one if you want. -------------------- Trouble rather the tiger in his lair, than the sage among his books.
Posted: February 09, 2010 02:12 am
hopefully i am good for a while .
i sure will keep that in mind though . |
