| jamesgr |
Posted: February 05, 2010 09:47 pm
Newbie ![]() ![]() Group: Members+ Posts: 45 Member No.: 22,161 Joined: January 20, 2009 |
From a little water wheel I can get a fairly constant 0.4 V.
Can I use such a small amount of electricity for anything useful? cheers all |
Posted: February 05, 2010 09:52 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Cleanup Taskforce Posts: 23,216 Member No.: 5,746 Joined: July 24, 2006 |
Not much...you need at least 1V to do anything with it. Even the very lowest voltage boost converters need .5V or more to operate. About all you can do with voltage that low is turn it into heat, & probably not much of that. If you use a mechanical speed increaser, like a belt drive, won't it increase your generator output?
-------------------- Trouble rather the tiger in his lair, than the sage among his books.
Posted: February 05, 2010 11:50 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 13,476 Member No.: 15,154 Joined: May 15, 2008 |
ps ... don't forget about current (besides that of/in the water) .
E X I = Watts (aka : work) if you measure the current from that generator putting out .4 volts and it is (say) 100 mA ... increasing the voltage to .8 volts will only give you 50 mA available . at 1.6 volts this would be 25 mA ... and so on . "no free lunches" |
| ChipUser |
Posted: February 06, 2010 12:18 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 1,898 Member No.: 15,445 Joined: May 30, 2008 |
Another thing to think about is if you are measuring the 0.4 volts at no load.
As you start loading the generator, the generator will start resisting the force of water and start to slow down - further reducing the generated voltage. Just to experiment, try connecting a 1.5 volt flashlight bulb (from a flashlight that runs on a single 1.5 volt cell) to the generator. You may get a mild orange/yellow glow from it. |
| Fallingwater |
Posted: February 06, 2010 12:52 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 2,812 Member No.: 8,638 Joined: March 14, 2007 |
25 mA at 1.6V would be enough to dimly run a red LED or something... if it wasn't for the converter issues mentioned by Tekwiz. -------------------- One man's trash is another man's treasure.
--- In Tekwiz we trust |
Posted: February 06, 2010 12:57 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 9,201 Member No.: 5,314 Joined: June 04, 2006 |
LEDs actually start emitting light (dimly) at pretty low currents.
-------------------- Mac *
| AdamO |
Posted: February 06, 2010 02:40 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 1,817 Member No.: 12,522 Joined: January 03, 2008 |
Yeah but if you want to boost that, you need something active. Silicon doesn't start playing until you get to 0.6-0.8V. IMO the best way to boost the output is to get a larger input source: drive the water wheel with a higher velocity, higher pressure stream of water.
Alternatively, add coils to the generator. -Adam O. |
Posted: February 06, 2010 02:51 am
It might be possible to create a germanium-based voltage tripler or quadrupler by utilizing a mechanical switch on the water wheel, but it would require the .4V to remain steady under a bit of load.
Just a thought. -------------------- Mac *
| Village Idiot |
Posted: February 06, 2010 06:09 am
![]() Forum Addict ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 924 Member No.: 11,398 Joined: October 08, 2007 |
You could use a zero threshold MOSFET to build an amplifier or some other gadget. They will work with power supplies as low as 0.2 volt (and possibly even lower).
http://www.aldinc.com/ald_przerothreshold.htm -------------------- My brain hurts.
| telomere |
Posted: February 06, 2010 06:16 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 3,195 Member No.: 9,502 Joined: May 18, 2007 |
I must have been thinking about this or something, because last night, in a dream, I found the answer....
What can he do with 0.4v? Put ten of them in series. |
Posted: February 06, 2010 08:14 pm
Either that, or switch to an AC generator, so a transformer can be used. -------------------- Trouble rather the tiger in his lair, than the sage among his books.
Posted: February 07, 2010 12:05 am
Best idea yet IMO. -------------------- Mac *
| Faraday's Cage |
Posted: February 07, 2010 01:29 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Cleanup Taskforce Posts: 1,451 Member No.: 7,707 Joined: January 06, 2007 |
Use a "vibrator" (no, not that
-------------------- I am not to be held responsible for any outcome created if you choose to practice anything I've posted above.
Posted: February 07, 2010 05:46 am
hmmm ...
what is the Vfwd of the IR led in an opto isolator ? |
Posted: February 07, 2010 09:49 pm
![]() Forum Addict ++ Group: Moderators Posts: 15,158 Member No.: 73 Joined: July 24, 2002 |
Oh, besides zero threshold MOSFETs, they also make depletion mode MOSFETs and JFETs. Less common, but they are "normally on". With a typical "joule thief" circuit and a lot of gain (more turns on the feedback winding than the primary), you should get something that oscillates at arbitrarily low voltages (0.1ish?).
Tim -------------------- Answering questions is a tricky subject to practice. Not due to the difficulty of formulating or locating answers, but due to the human inability of asking the right questions; a skill that, were one to possess, would put them in the "answering" category.
| jamesgr |
Posted: February 08, 2010 03:59 pm
Thanks guys,
Fascinating stuff. |
Posted: February 09, 2010 03:03 am
Hmm, never thought of using depletion mode semiconductors. That opens up some interesting possibilities. Such a converter would be very limited power wise, though. At that low a voltage, you'd need enormous currents to produce any reasonable amount of power. -------------------- Trouble rather the tiger in his lair, than the sage among his books.
