> Resistors Over Transformer
evildragon
Posted: November 03, 2009 09:12 pm
I just thought of something.
Wouldn't a network of resistors take the job of a transformer and step voltage down?
Or am I misunderstanding ohms law?
Apple Mac Pro, Dual Xenon Quad Core 2.8GHz, 32GB RAM, 350GB HD, ATI Radeon 4870, Mac OS X 10.6 / Ubuntu 9.10 64-Bit
Compaq Presario Notebook CQ61-313US, Dual Core AMD Athlon II 2GHz, 4GB RAM, 250GB HD, ATI Radeon 4200, Windows 7 Home Premium 64-Bit
Posted: November 03, 2009 09:29 pm
Sure, place a pot across a given voltage and use the wiper to derive any voltage between the rails, but keep in mind how much power that pot has to dissipate whether the tap is floating or loaded. If you need anything above milliampres then the resistors have to be big and they're burning up a lot of the supply as waste heat. To get tens of amps at a tap at 1/2 the mains voltage you'll be burning up KiloWatts just to get there.
It should be noted that this method was (is) acceptable for biasing tube elements, such as focus and grids in CRTs where very little current was required and the total divider might run 50-100 MOhm between the 'ends'. But for supplying low voltage electronics in general? No way.
Some very old AC/DC radios did use dividers on the input. I guess efficiency wasn't on peoples minds then. Nor was safety. Running heaters (and sometimes lamps) in series string across the mains to avoid a transformer wasn't uncommon either.
Stranded in time. Surrounded by evil. Low on gas...
"On a long enough time line - the survival rate for everyone drops to zero."
When the going gets wierd, the wierd turn pro. Hunter S. Thompson.
VenomBallistics
Posted: November 03, 2009 09:51 pm
works great, voltage dividers have done this since man discovered that he could electrocute himself :P
now the issue with it is that it is not a one size fits all solution.
if you need substantial current to go with that order of lower voltage, its a transfos job since most resistors as we know them will smoke above their rated .25 watts.
Colt45
Posted: November 03, 2009 09:53 pm
gotta be piss low current, or it's uber inefficient.
PMEmail PosterICQ
Roccivic
Posted: November 03, 2009 10:02 pm
Stepping 120V to 12V would mean 10% efficiency :P
No isolation either... A faster way to die if you are playing with mains.
The information above is correct to the best of my knowledge, I however will decline any responsibility in case of any injury, damage or whatever else anyone could possibly sue me for caused by use of the above information. Use at own risk!
Posted: November 03, 2009 10:09 pm
It's 100 percent inefficient, no? Whatever you want out of the divider has to burned up again across the supply.
Note that the example of series heaters on the other hand is 100 percent efficient (outside the tubes themselves) as all of the input is directly being converted to the job at hand.
I wonder if there were any layouts ever built with the doubler/B+ divider pulled directly from a rectified (indirect heater) series, with the cathodes pulled from the bottom end of a lamp, and grid from just above? Or if such a layout would have worked.
Posted: November 03, 2009 10:26 pm
QUOTE (Jimthecopierwrench @ November 03, 2009 01:09 pm)
Huh? Say what? :huh:
Learn from the mistakes of others. You can't possibly live long enough to make them all yourself.
Defeco, ergo sum.
Posted: November 03, 2009 10:38 pm
Yeah, something that would need to be drawn. I can picture it in my head but it doesn't translate well to text. Might scribble it later.
Posted: November 04, 2009 12:15 am
i think i know what he is talking about ...
sounds like something that was used in "el cheapo" radios .
but you get right back to the isolation/shock hazard issues .
i got knocked on my butt when i was 6 by a transformerless AA5 .
the volume control ("D" shaft) knob had split out .
sooo ... i grabbed it with a pair of pliers . i happened to be leaning across the gas range when i did it .
let me tell ya , i almost peed myself a little .
polarized plug ? what polarized plug ?
Posted: November 04, 2009 12:16 am
QUOTE (Jimthecopierwrench @ November 03, 2009 03:09 pm)
I've heard of some amps that heated the front end's 12AX7s with the 6L6 output tube's cathode current.
AA5 radios often have the diode connected to a tap on the rectifier's heater, to reduce peak surge current. (The tap is usually provided for lighting a small 6.3V panel light.)
Posted: November 04, 2009 01:02 am
