> Measuring Resistance With A Pic Microcontroller?
nigelmercier
Posted: November 03, 2009 06:25 pm
I want to make a replacement fuel gauge display for a boat, using a PIC microcontroller.
The sensor is a variable resistor activated by a float in the fuel tank; one terminal is connected to the 0V rail (although it may be possible to isolate it if necessary). The resistance of the sensor is to to be verified, but is likely to be either 0 Ohm to 180 Ohm, or 0 Ohm to 300 Ohm.
The existing display is a moving coil meter in series with the sensor and the 12V rail.
What would be the best way to use the existing sensor?
Nigel
Posted: November 03, 2009 07:16 pm
What kind of display? Digital or analog?
Check also the the fuel level sensor isn't actually a 'stepped' sensor (magnet running up/down a tube having reed switches in it).
Assuming it's a vairable analog signal it's a matter of making a voltage divider and measuring the resultant volatge and making up your own scaling factor.
Roccivic
Posted: November 03, 2009 07:59 pm
QUOTE (Big_Nige @ November 03, 2009 05:25 pm)
Why do you want to use a PIC for such a dumb task? What a waste of thousands of transistors...
As Dave correctly pointed out we can't really help if we don't know what you want to do...
telomere
Posted: November 03, 2009 08:04 pm
QUOTE (Roccivic @ November 03, 2009 11:59 am)
Why, are those transistors in a scarcity or something? With that crazy Moore guy making twice as many every 18 months, we need to do SOMETHING with them, or they're going to pile up all over the place, we'll be buried in them.
"Sometimes I can't tell the difference between thinking and being quiet, but I'll try."
kl27x
Posted: November 03, 2009 09:22 pm
+1. Each additional transistor is just a few more nanograms of silicon.
When you consider the potential for additional IC packaging of a multi-IC analog solution as well as potential inefficiencies (vs a microcontroller with smart power management), you might find the analog solution to be the wasteful one.
nigelmercier
Posted: November 04, 2009 12:00 am
I'm not sure it is relevant, but I'll answer your questions ...
The new display is to be both digital and analogue, showing percentage of fuel remaining as a bar, approx number of litres, trip fuel used, current engine running time, perhaps even rate of fuel use.
The tank is shaped like an elephant (or any similar irregular shape), so the current display is very non-linear. It stays at FULL for days, then drops like a stone. I want to make the device both as an exercise, and so I can have a more relevant display. Obliviously it will need to be manually calibrated.
Is a simple voltage divider sufficient? I figured it would need some sort of bridge - or am I showing my age?
Nigel
kl27x
Posted: November 04, 2009 09:49 pm
An ADC pin has a maximum recommended impedance, specified in the datasheet. For a typical PIC, 10k is the max recommended impedance. Any higher, and the results will be skewed. There is no minimum. The lower, the better. So you could hook the ADC pin up directly to a strong power source, so long as the max voltage isn't exceeded.
Just make sure your fixed resistor goes on the top side of the divider. Then your max voltage will be limited to where you want it to be. For instance, if your sensor has a max resistance of 300 ohms, you could remove the coil and replace it with a 600 ohm resistor. Then you'd have a voltage output of 0-4V, with a relatively low impedance.
If there is any noise in the voltage source, you can put a small bypass cap between ADC pin and ground rail.
millwood
Posted: November 08, 2009 01:12 pm
yeah, using a fixed resistor in serial with the fuel sensor would be the way to go.
I would choose a pic with internal voltage reference so you can also measure the Vdd to the mcu.
Posted: November 08, 2009 02:07 pm
The non-linearity of the current readout is usually becasue the wrong type of pick up sensor is fitted. In your case I suspect a 'lever arm' device is installed. That, or the sliding magnet/tube version is using a tube that is too short.
To do the measurements you describe though, you'll need to know the actual flow rate which will mean sensors on the fuel feed and return pipes.
millwood
Posted: November 08, 2009 02:14 pm
you can always calibrate the software to show the correct "volume", through a look-up table for example.
for example, you can pre-measure the relationship between volume and sensor value,
sensor volume
0ohm 1L
10ohm 2L
20ohm 30L
30ohm 50L
300ohm 934L
once you do the adc, you can figure out the true sensor resistance. then all you need to do is to look up that table and interpolate the volume.
that should be a piece of cake for the software.
millwood
Posted: November 08, 2009 02:16 pm
for flow rate, you will need to measure time (easy) and change in volume (more difficult but doable).
likely some kind of smoothing has to be done as well.
but having a flowmeter will be more accurate / easier / faster.
millwood
Posted: November 08, 2009 07:07 pm
I took this exercise to see how much of the old code i can reuse, smile.gif.
here is something I put together in half an hour. It consists of basically three modules:
1) a hd44780 driver that I wrote for a lcf meter I am working on right now. it acts as the display for the unit;
2) an interrupt based timer: based on a frequency generator I wrote earlier. it uses timer1.
3) an adc module that I had.
every pre-determined time (specified by the user), the timer sets up a flag to trigger the adc module, which measures the resistance, converts it into volumic information to be displayed on the LCD. the calculation uses floating point library and does exponential smoothing.
all of that done in 30 minutes, smile.gif.
it does not implement a calibration / look-up function to translate ohmic readings into volumic figures - now it is simply a linear function.
also, since it uses Vdd for adc reference (vs. a fixed reference voltage), the readings are subject to Vdd fluctuations.
I am happy to upload the source file if you want to see.
Posted: November 09, 2009 12:07 am
Unless the tank sending unit has some kind of mechanical damping, you will need to include a low pass filter on your fuel level signal (implemented in PIC code of course) to prevent the fuel level display from bouncing all over the place as the fuel sloshes around in the tank.
For fuel flow measurement, if your engine has electronic fuel injection, then the easy way is to monitor the signal to one of the injectors. It will be a PWM signal proportional to fuel flow.
millwood
Posted: November 09, 2009 02:02 am
exponential smoothing is a digital low pass filter.
Posted: November 09, 2009 03:15 am
QUOTE (millwood @ November 08, 2009 07:02 pm)
I missed that part of your post.
NGinuity
Posted: October 27, 2010 07:35 pm
Hi, I was wondering if you still had this code lying around? I'm looking to do something a little simpler, with a 10 segment LED bar and this would save me a ton of time.
Thanks in advance :-)
-Eric
