> 90 Degree Shaft Coupling - Spring? Wire Rope?
ingre_dients
Posted: August 24, 2009 04:57 am
I'm new to the forum but saw this section and thought I'd post a Q here.
Does anyone know what the smallest, simplest way is to transmit a shaft rotation 90 degrees is?
Bevel gears are sort of out of the question for me I think b/c of price and having to position them, etc.
I've made many spring couplings, but I've had trouble with the springs forming a curvature after time (and hence a very wobbly.. result). THe springs however were hand made and heat-treated in a toaster oven - so they probably weren't done right!
But I've never messed with wire rope, o-ring cord, or anything like that - if there are any ideas, I'd be happy to hear. Or, if someone knows something about these springs that I don't.
Just for reference, I have been using a 1/16" shaft turning with a friction-fit spring around it made from something like .016 spring wire.
I know they make some fancy wire rope couplings that are expensive, and I'm not sure how they are made, but I've only seen them long - like 6 inches or something, where I'm looking for something shorter, much more light-duty, less expensive, and that I could possibly make my darn self.
Posted: August 24, 2009 07:11 am
Depending on the load, a rubber wheel (or one with a rubber tire/o-ring/etc.) running on the flat surface of a rotating disc should make a decent 90 friction drive in a small area.
If desired, you could even change the drive ratio by setting the rubber wheel nearer/farther from the disc center.
Also, a round (or pointed) edge on the rubber wheel will heat (and wear) less, as the surface speed of the disc changes with diameter, and you want to span as little of this variance as possible with the rubber wheel.
Something like this perhaps (a bit smaller disc/wheel could be used).
       _
      | | Disc
 _____| |_
 _____| |_|
      | |         Rubber
      | |       _ wheel
      | | _____|_|_____
      | |<_____________>
      |_|      | |
Just a thought.
Posted: August 24, 2009 01:19 pm
Two CVs?
Posted: August 24, 2009 07:45 pm
For very small apps, you basically have 2 choices; A flex shaft, like a speedometer cable, or bevel gears. The flex shaft will require much more space, as there are severe limits on the minimum radius it can assume. Look around, as there are bevel gears made in virtually any size you could possibly want. cool.gif
BTW: Price need not be an issue, as you can likely scrounge something that has suitable gears in it. Positioning need not be an issue either, as you have to position the shafts at 90 anyway.
ChipUser
Posted: August 24, 2009 11:40 pm
If the spacing between the two shafts is not critical, how about using dial-cord like pulleys & belt arrangement? You will need about 4 pulleys. Two of the pulleys will be oriented in a direction that is at 90 deg to the pulleys on the shaft and in parallel. The remaining two pulleys will be mounted on the shafts. Hope I haven't confused you with my description.
ingre_dients
Posted: August 26, 2009 04:47 am
Thank you all very much for the replies and sorry about this late reply.
Those are great designs. I really like the rubber roller with disk in the diagram that you posted MacFromOK. I would never have thought of that. I think thats a great idea because of the simplicity and because of the range of speed.
Thanks for giving me more confidence on the bevel gear idea too tekwiz, maybe they are something to try as well if I could get a housing that is minimal enough. I've never really used gears very much, only lots and lots of pulleys, but I will give it a try.
I think I may know what you mean about the dial-cord pulley system Chipuser. I've used a lot of pulleys but have never tried that, and it seems a little complicated but also within my range of ability.
Thanks a lot for the comments, being new to the forum I'm totally amazed at the knowledge here and would like to be able to contribute soon and keep the ideas moving.
Posted: August 26, 2009 06:45 pm
Unless you are running at high speeds for extended times, you may not need a housing at all. wink.gif
BlueVanACD2005
Posted: August 26, 2009 10:37 pm
I think he means something between the gears as opposed to an enclosure type thing? I sort of picture a small peice of angle metal with two 90 degree shafts through it...
-Spenser
PMEmail PosterUsers WebsiteYahoo
