| JoOngle |
Posted: June 23, 2009 10:56 pm
![]() Forum Addict ++ Group: Moderators Posts: 7,856 Member No.: 3,818 Joined: December 12, 2005 |
Today is a GOOD day,
For the first time in my LIFE, I've actually managed to use a Tube and make it work, and understand how it works. (Yes, I know - that's no great achievement, rather lame actually...) But for some reason, the "tube lore" has always been hovering above me, most of you regulars in here KNOW this, and I haven't really experimented a lot, just tried to dabble in old books with math WAY over my understanding so I never truly "got it" before today! The reason? I just tried it out, found a triode, blew one up, and had success with another. So what did I do? Make it amplify something, just like a transistor, I think Tim in here wrote once, it's even simpler than transistors to use, and now I understand what he meant - they're truly simple to use, dangerous as h... but simple. Why can't books explain it for how simple it is? It's so simple it's sort of stupid, while feeling great for having it worked out and having a working example of the theory, it's so simple that a kid of 5 could do it. And for the other people who "look forever" for the same simple information it's darn simple: - Connect the specified Heater voltage to the Heater pins - Connect the high voltage to Anode and Cathode, eg. the + to the Anode (possibly with a 10K resistor between the Anode and 200v if you plan to draw the difference between the anode and the 200v+) - The grid is your "B" base pin, just like the transistor, anything you input there, will be amplified and can be drawn out between the 10K resistor between the high voltage psu and the anode... Why don't anyone describe it like that? it's so bloody simple! Dang...that was what I didn't get before? (pounds head!) I'm actually quite amazed how well they perform as well, the amplification is by no means meager and bad. Ok, thats it - I'm going to make my very first tube radio now, can't wait! Man, I'm going to sleep good tonight. -------------------- If my soul was software, I could program myself and you.
Posted: June 24, 2009 02:37 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 19,517 Member No.: 15,154 Joined: May 15, 2008 |
cooolll ...
what tube were you using ? you might try a regenerative circuit for the radio ... fairly simple , low parts count and they can be surprisingly sensitive . you might have to use a pre-selector on the front end to improve the selectivity if you live near high powered stations . ps ... you have to let us know the first time you get bit . -------------------- "Know how to solve every problem that has been solved"
| ChipUser |
Posted: June 24, 2009 03:33 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 2,373 Member No.: 15,445 Joined: May 30, 2008 |
I almost read the title as "my test tube baby's first steps"
Congratulations! |
Posted: June 24, 2009 04:43 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 12,951 Member No.: 5,314 Joined: June 04, 2006 |
As a non-tuber, I'm impressed if no one else is Jo.
Gonna put the radio circuit in this thread or start another? -------------------- Mac *
| draget |
Posted: June 24, 2009 05:47 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Cleanup Taskforce Posts: 5,484 Member No.: 1,770 Joined: December 31, 2004 |
Wouldn't it be slightly pointless to connect the valve without a load?
Now add cathode bias and some coupling caps and you have an audio signal stage |
Posted: June 24, 2009 05:54 am
![]() Moderator Group: Moderators Posts: 8,904 Member No.: 62 Joined: July 23, 2002 |
Congratulations!!!
You hit the key phrase with these glassfets: "it's darn simple". Cheers! -------------------- -= Gregg =-
| JoOngle |
Posted: June 24, 2009 04:12 pm
@CWB
It was an EC92, and I've been bitten long before I even knew how it worked, you know...even though tubes where LONG before my time, that glow was just magical to me. @ChipUser, lol - test tube baby... @MacFromOK, Thanks, well - It'll probably be in this thread, I'll have to experiment a bit more, you know - get my hands dirty (hopefully not get shocked & dead) first, then I'll do stuff - you can believe that! @Draget, To figure out how it worked - was not really pointless in any way, for an experienced user - yes, to me? Baby-steps.... anyhow, I'll have to go the Audio-Amp way as you suggest, I'm reading up upon a 60 year old tube-electronics book from Denmark now, so we'll see. @Geek, LOL! Glassfets - perfect name. -------------------- If my soul was software, I could program myself and you.
Posted: June 24, 2009 06:06 pm
It is a good name, as field effect transistors are the closest semiconductor to tubes. In some circuits, they can be used as a direct substitute. Tom, tubes are very simple to understand, much easier than transistors. Did you look up a basic description of how they work?
BTW: Congrats. Feels good, don't it? -------------------- Trouble rather the tiger in his lair, than the sage among his books.
| JoOngle |
Posted: June 24, 2009 06:50 pm
Didnīt know that Tek, thanks for the heads up!
I have looked it up many times, but didnīt understand them before I tried them in actual practical use. I was so irritated and annoyed that I didnīt get something so supposedly simple, so what I did...was to just connect them to their specs according to the Datasheets, and experimented with inputting and outputting current and checked for variations, the darn books...just showed a LOT of fairly complex math formulas that I didnīt get (sorry - Iīm no math genious) I think Iīve told that numerous times - the no #1 reason for me having so many test-instruments is that they have always thaught me what happens INSIDE each component, and circuit - thats how I was capable of building a FM radio from scratch without schematics, thats how I built and programmed a robot from scratch... I *must* learn from doing, I can understand theory on a platonic level, but I have this thing that "prohibit" me from learning if I donīt understand EXACTLY whatīs going on... ...I canīt just "grasp huge math theories" and understand how to build a circuit out of that just like some of those with YEARS in schools can... for students - this is hard to understand - that I canīt just like they can... ...even more baffling for them...when I understand it in "practice". I credit the "instruments" for that knowledge. If you catch my drift? And yes - if feels GREAT! -------------------- If my soul was software, I could program myself and you.
Posted: June 24, 2009 06:54 pm
No math needed to understand tubes; triodes at least. The heater boils electrons from the cathode, which are attracted to the positive plate, unless repelled by the grid. It's that simple.
Posted: June 24, 2009 09:17 pm
![]() Forum Addict ++ Group: Moderators Posts: 18,143 Member No.: 73 Joined: July 24, 2002 |
Huge equations? I challenge you to find anything with more than three terms and five variables in RC-26 or so (RCA Recieving Tube Manual). The most important are equivalent to Ohm's law.
Sounds to me it's time to turn your fear of math into an integrated part of your understanding of the world. Tim -------------------- Answering questions is a tricky subject to practice. Not due to the difficulty of formulating or locating answers, but due to the human inability of asking the right questions; a skill that, were one to possess, would put them in the "answering" category.
| mravenca |
Posted: June 24, 2009 10:01 pm
![]() Sr. Member ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 319 Member No.: 1,899 Joined: January 25, 2005 |
I think that there is nothing much difficult in understanding a tube linear model, it's similar to transistors.. (h and y parameters,..)
Programmer is a machine that turns coffee and cigarets into software |
| mravenca |
Posted: June 24, 2009 10:05 pm
Anyway, my father told me once that they used tu use a huge rf power tube as a lamp in his room in dormitory, during his studies
Posted: June 24, 2009 11:33 pm
A rather inefficient way (thoriated tungsten filaments operate about 2/3 the temperature of an incandescent bulb), but very nice for ambiance.
Posted: June 25, 2009 01:02 am
yessir ... "mood lighting" and semantics .
that would really impress some woman you invited over . -------------------- "Know how to solve every problem that has been solved"
Posted: June 25, 2009 07:57 pm
Not to mention that "feeling of warmth" that comes from a >500W cathode heater.
