| Pages:««<23456 ( Go to first unread post ) | ![]() ![]() ![]() |
Posted: February 06, 2008 02:42 am
Stranded wire works as solder wick, too. It's also much cheaper than coax.
-------------------- Trouble rather the tiger in his lair, than the sage among his books.
| cockney-steve |
Posted: February 06, 2008 12:29 pm
Member ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 226 Member No.: 1,933 Joined: January 29, 2005 |
Adam, I like that one
but doesn't EVERYBODY have a loft, with a budgie -cage and a load of 75 ohm coax from the old, 405 line aerial? |
| kl27x |
Posted: February 27, 2008 06:04 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 3,861 Member No.: 4,223 Joined: February 06, 2006 |
Well, I just found this trick useful. I'm glad I read it. Sure, I have a propane torch and a desoldering iron, but this was way quicker, cuz I had some appropriate wire within arms reach.
| EveryReasonTo |
Posted: March 20, 2008 11:53 pm
Sr. Member ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 453 Member No.: 13,873 Joined: March 16, 2008 |
Only simple, but i keep all spare pieces of wire (long and short) in a box for when i crack the breadboard out, don't like waste!
I do the same with old pcbs that i think look 'interesting', sometimes for salvaging components off, other times so i can re-use em. Found an old power supply from an xbox earlier, can be used as a quick psu. |
Posted: May 16, 2008 07:32 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 19,509 Member No.: 15,154 Joined: May 15, 2008 |
the old strings from electric guitars make for a great way to remove solder from holes in a pcb .
they come in several gauges . just cut them to a convenient length . heat the solder and rapidly run the piece of wire back and forth through the hole . the wrapped strings are particularly effective . i have some mounted (drilled and epoxied) in small diameter short length wooden doweling . i color coded the different sizes for easy grabbing . This post has been edited by CWB on May 16, 2008 07:34 pm -------------------- "Know how to solve every problem that has been solved"
Posted: May 16, 2008 10:17 pm
I do the same myself. I keep all wire from stuff I junk for parts. I have a large wire box & now I only have to purchase wire when I need a long piece. I also have several boxes of circuit boards that I keep as a parts mine, for when I need a resistor or cap that isn't in my regular stock. I usually only pull a few of the more important parts off of a board when I remove it for junk; the rest goes into the parts mine. -------------------- Trouble rather the tiger in his lair, than the sage among his books.
| CGFxColONeill |
Posted: May 22, 2008 04:08 am
Forum Addict ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 502 Member No.: 15,233 Joined: May 20, 2008 |
what is the best way to disassemble a hard drive w/ out a star tip? -------------------- Overconfidence - Before you attempt to beat the odds, be sure you could survive the odds beating you.
I am not sure if Life is passing me by or running me over. |
Posted: May 22, 2008 12:08 pm
![]() Forum Addict ++ Group: Moderators Posts: 18,140 Member No.: 73 Joined: July 24, 2002 |
Hammer?
...Maybe not... Best bet is finding a tool that grabs the screws... pliers or cutters if necessary (gripping inside or out, whatever works). Or chisel on the side of the screw to rotate it, that's also good for stuck screws. Tim -------------------- Answering questions is a tricky subject to practice. Not due to the difficulty of formulating or locating answers, but due to the human inability of asking the right questions; a skill that, were one to possess, would put them in the "answering" category.
Posted: May 22, 2008 06:57 pm
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 12,945 Member No.: 5,314 Joined: June 04, 2006 |
Someone recently mentioned cutting a slot in them with a dremel then using a standard screwdriver. Might be able to do that with a hacksaw as well...
-------------------- Mac *
| CGFxColONeill |
Posted: May 23, 2008 02:12 am
thanks for the tip got another question
what is the procedure for soldering or un-soldering IC chips? do you just heat the leg like a regular component or are they negatively affected by the heat from doing it like that? thanks -------------------- Overconfidence - Before you attempt to beat the odds, be sure you could survive the odds beating you.
Posted: May 23, 2008 02:20 am
you want to get on and off them as fast as you can . they don't like excessive heat .
solder wick , solder sucker and a pick . a low wattage soldering pencil ... adjustable units are nice . heat the solder directly ... not up on the leg . keep your tip clean . i keep a little extra solder on the tip ... it helps to conduct the heat to the work faster . -------------------- "Know how to solve every problem that has been solved"
Posted: May 23, 2008 02:36 am
Some of the guys have reported good success with a propane torch and whacking the board to jar them out. Only if you don't want to keep the board though. This has already been covered somewhere, perhaps in this thread (not sure).
Btw, this thread is for sharing tips, not Q&A. -------------------- Mac *
Posted: May 23, 2008 02:40 am
One leg at a time. It is actually pretty hard to heat damage most components, you really have to bake them. Most components will withstand soldering temps for many seconds without problems. When removing a dead IC, sometimes it pays to cut all of the legs with small side cutters, & then desolder the stubs one at a time. -------------------- Trouble rather the tiger in his lair, than the sage among his books.
| phoebus16 |
Posted: March 25, 2009 12:50 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 1,638 Member No.: 7,723 Joined: January 08, 2007 |
This thread got forgotten for long time
Anyway, Big buttons from broken calculators or other devices can be hot glued and used as feet for project cases. These on the pic are rubber ones from a calculator: ![]() edit ... touched up the pix a little . cwb -------------------- Those who dream by day are cognizant of many things which escape those who dream only by night. ~Edgar Allan Poe
| AdamO |
Posted: June 01, 2009 07:54 pm
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 2,304 Member No.: 12,522 Joined: January 03, 2008 |
For storing MOSFETs and other TO-220 MOS devices (up to 5 pins): My new dumb little trick is to stick them on an extra breadboard, one part on one bus to short all the pins to each other. Foam's probably better but I don't have any and this is better than having them lounging around in a plastic drawer. And I ordered my breadboards from China: got like 6 of them for 10 bucks, so I can get away with using one of them in this manner.
-Adam O. |
| megadanny1 |
Posted: June 23, 2009 12:19 am
Newbie ![]() ![]() Group: Members+ Posts: 14 Member No.: 24,646 Joined: June 13, 2009 |
if your just trying to get a burned out IC out shove a screw driver under it and pull up it will break the ic off and then just de solder the pins
Posted: June 23, 2009 02:05 am
... just don't tear up the board in the process .
Posted: June 23, 2009 06:15 pm
No kidding. There are lots of ICs that are quite a bit stronger than the board beneath them. Cut the legs with a Dremel or small cutters, then unsolder the legs one at a time. If the board is especially complicated, the new IC can be soldered directly to the leg stubs from the old one, to avoid damaging delicate traces on the bottom of the board. -------------------- Trouble rather the tiger in his lair, than the sage among his books.
Posted: July 24, 2009 07:02 am
![]() Moderator Group: Moderators Posts: 8,891 Member No.: 62 Joined: July 23, 2002 |
EIA manufacturer codes. Can help identify what you have from those mysterious numbers (not all manufacturers got a code and some didn't play by the rules)
-------------------- -= Gregg =-
| PIC |
Posted: December 06, 2009 04:19 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Cleanup Taskforce Posts: 1,031 Member No.: 6,662 Joined: October 08, 2006 |
The top part of the metal casing of VCR's is useful as a work surface when soldering or using a glue gun. Remove the top casing from the VCR and bend the sides out so it's all like a horizontal sheet.
Regards PIC -------------------- "Plunge into the depths until you reach the truth." Imam Ali (a)
| sherlock ohms |
Posted: December 31, 2009 01:54 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 2,764 Member No.: 26,125 Joined: September 10, 2009 |
old egg cartons make ideal containers for golf balls..
-------------------- "Quotation marks make sentences appear more meaningful."
| Audiotek |
Posted: September 03, 2010 04:48 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 2,693 Member No.: 19,960 Joined: October 30, 2008 |
Seam ripper to undo the tight braided shield mostly for that pesky Belden 1192A Start with the sharp edge and use the dull side to unbraid.
| Audiotek |
Posted: September 03, 2010 05:00 am
2 single edge razor blades flip at 180 and slightly shifted, put some tape around and it's perfect to slice open heavy jacket cables. I use it a lot when I make heavy gauge AC extension cords. Slice on both side of the cable then pull down on the 2 pieces of jacket to have fresh untouched wires inside
The deepness of the blade gets adjusted by the shifting of the 2 blades. That method is so fast and I am so used to it by now that I use it on mic cable and even smaller cables. |
| kellys_eye |
Posted: November 08, 2010 01:41 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 9,979 Member No.: 2,735 Joined: June 21, 2005 |
Tip - Don't put an electric heater underneath the (metal) cabinet housing all your heatshrink........
Don't ask. -------------------- May contain nuts
Posted: November 09, 2010 10:43 pm
on the bright side ... you now have drawers full of spaghetti .
Pages:««<23456 |
