> LCD Problems
straightexhaust
Posted: December 21, 2006 08:41 pm
Ok I just finished making on of these parallel port lcds I bought a lcd with black background with red text. The problem is tht the text isn't bright enough and when i dim the backlight with a pot tht i soldered between the board and the positive led lead it also dims the text. The chip for the lcd is the same as mentioned on the site above. I dont necessarily need the backlight i just want the text to be brighter.
Thanks Jason
Posted: December 21, 2006 08:48 pm
LCDs don't generate their own light, they only reflect what's already available - failing that they can, as your display does, they pass or block a fixed backlight.
You can only make the display as bright as the backlight goes.
You could always change the backlight LED to something brighter....
straightexhaust
Posted: December 21, 2006 09:06 pm
But the broblem is the contrast the backlight illuminates each little segment and you can only read the text at an angle not straight on.
Gorgon
Posted: December 21, 2006 10:24 pm
Have you got a contrast adjustment, and tuned it to max contrast?
Is the backlight LED current nominal?
Light travels faster than sound. That's why some people appear bright until they speak!
straightexhaust
Posted: December 21, 2006 10:34 pm
how would i adjust contrast
Gorgon
Posted: December 21, 2006 10:38 pm
Post the type number and manufacturer of your display, I'll need this to get the datasheet.
Posted: December 21, 2006 10:55 pm
^yup, there's usually a pin on the connector dedicated to the contrast voltage.
Gorgon
Posted: December 21, 2006 11:09 pm
You can use this circuit user posted image
The ssc2b16 datasheet say Vdd - Vo = 4.4V -> 0.6V from 0V(Vss) not much but the contrast range is not very great on this displays. I suppose it is way too dark now with 0V in.
Audioguru
Posted: December 22, 2006 01:40 am
Red on black??
I have an LCD clock with big black numbers on a light grey background. Easy to see.
A backlight or contrast control isn't needed.
It operates from a 1.5V button cell.
Posted: December 22, 2006 09:51 pm
Jason probably has one of those transmission type of 'reversed' LCD, where the segments become clear when energized, & the background remains black. They work like the regular kind of LCD, the difference is in the polarising filter, & how it is aligned. Most LCDs suffer from poor off-axis visibility. Make sure that your backlight isn't made to run from a higher voltage than you are supplying, it may need 12vdc for full brightness. Your display may also have a faulty polarising filter, although that is unlikely. cool.gif
straightexhaust
Posted: December 24, 2006 05:36 pm
Thanks for all the help but....sadly its now fried so im going with the typical black on green style w/ backlight. Ill order that today. I had the red one hooked up to my pc and everything and even had pc specs scrolling across it but the contrast sucked so im going to buy the black on green style. Thanks, Jason
