> I Need A Bit Help
Posted: December 17, 2016 10:26 pm
okay it does sound stupid, but geesh.. i can't figure this out.
the "problem"
we take a 4 digit number, and add to it it self without its last digit, then again without 2 digits, then without 3 digits, and then we get 2016.
what was the number we where thinking about?
so if my 4 digit number is ABCD,
then
ABCD+ABC+AB+A = 2016
how on earth you make an equtation that can describe this at all ??
PIC
Posted: December 17, 2016 11:54 pm
Hi,
Say the digits are A, B, C, D. That means each letter stands for a number that is between 0-9.
ABDC (e.g 1234) is made by A*1000 + B*100 + C*10 + D
ABCD doesn't mean A x B x C x D, as the letters are simply each digits 0-9 which you shift into the right position using x10, x100, etc.
When we do that adding operation you described:
2016 =
+ A*100 + B*10 + C
+10*A + B
+ A
The first line is a summation which converts the single digits A, B, C, D (each of which is 0-9) into the number ABDC, and same idea for ABC, etc.
Collecting terms:
1111*A + 111*B + 11*C + D = 2016
You have 4 unknown digits and only one equation, whereas you need the same number of equations as unknowns in order to solve.
However, from the way the question was set up, you do know that each variable must be whole number that is from 0-9. The only way I know how to go about this is by brute force - to try every possible combination of A, B, C, D and see if you find a solution along the way. Matlab script that does this:
CODE
%sweep over A from 0-9
for A = 0:9
   %for each A, sweep over B from 0-9
   for B = 0:9
       %and so on for C and D
       for C = 0:9
           for D = 0:9
               if (1111*A + 111*B + 11*C + D) == 2016 %does this combo give the right answer?
                   disp([A B C D]) %displays the solution if it finds one
               end
           end
       end
   end
end
Completes in an instant, and of the 10, 000 combinations it iterates through (0000 to 9999), there is one solution: A=1, B=8, C=1, D=6.
So if we say the number ABCD corresponds digit-wise to 1816, then 1816+181+18+1 = 2016 as sought.
I can't answer that I just coded it up laugh.gif I shared your confusion up that point it's more involved than it first seems.
Posted: December 18, 2016 09:09 pm
Given the way the 'equation' is given you need to look at it a little differently...
Firstly: break it down and add a few of your own unknowns..
A+B+C+D = X6 ( or rather X*10 + 6)
A+B+C+X = Y*10 + 1
A+B+Y = Z*10 + 0
A+Z = 2
Now we need to apply a few rules...
0<=A<=9; 0<=B<=9; 0<=C<=9; 0<=D<=9 ...
But also, X>=0, Y>=0, Z>=0
So with A+Z=2 that reduces A and Z to <=2
If B, C & D = 9 then X<=3, and Y<=2.... (Maximum possible Carry's, Our unknowns)
So now we look at A+B+Y .... if A=2, Y=2 and B=9 the max Z could be is 1...
Ahh now .. we have..
0<=A<=2; 0<=B<=9; 0<=C<=9; 0<=D<=9 ...
0<=X<=3; 0<=Y<=2; 0<=Z<=1 ...
So now .. A+B+Y = Z10 (0 or 10) But A+Z = 2 so A>=1
BUT if A=2 then B+Y=8 and Z=1. Thus A=1 and Z=1...
Now we have...
1+B+Y=10 or B+Y =9
1+B+C+X = Y10+1 or B+C+X=Y10 (10,20) : Ahh Y>0 Because 9+1=10 (if B=9 and leave C+X out), So now 1<=Y<=2, 7<=B<=8..
Dig in again, If B=7 then C+X = 17 which means X>=8 C+X = 13 which means X>=4.. no good, thus B=8 and Y=1.. now we have..
1+8+C+X = 10+1 or C+X = 2
1+8+C+D = X10 + 6 or C+D+3 = X10 (10,20) : X cant be 0 or 3 because C or D cant be negative.. So now 1<=X<=2, 0<=C<=1..
Dig in once more, If C=0 then X=2 and D=17, No good... So C=1 and X=1..
Now we get left with
1+8+1+D=10+6 or:
D=6
Solved... Without Brute Force.....
...EDIT...
Fixed a error in calculations..
Give me a Break... I'm dik-lic-sic, dus-kik-lic.... Gawd ... F'ed in the Head...
Posted: December 18, 2016 09:36 pm
i was able to figure out the answer, but i found no way to write it down with math.
Posted: December 19, 2016 12:30 am
Posted: December 19, 2016 01:53 am
QUOTE (gremlinsa @ December 18, 2016 02:09 pm)
phin
Posted: December 23, 2016 02:41 am
QUOTE (MacFromOK @ December 18, 2016 07:53 pm)
[/QUOTE]
While working as an EE manufacturing engineer, I had to come up with a program to determine how much metal to cut from a rotating part to bring it into balance. Now, I was never a math wiz and this was well beyond me. I told my boss the problem and he called in a mathematician to give me an equation. After a week of beating his head against the wall, he told me to brute force the solution. ie try an answer, look at the error resulting and modify the answer until the result was within tolerance. Worked fine and the computer did not seem to mind. Although MANY electrons were mistreated along the way!
Posted: December 23, 2016 07:20 pm
QUOTE (phin @ December 23, 2016 03:41 am)
In a case like that you need a Engineering Mathematician... Knowledge of metal density's, rotational balancing sensor sensitivity, etc.... Bet you this is where he was banging his head!!!
