> Mikroc Problems With Software
Mattyz
Posted: April 05, 2012 01:13 pm
I've just wrote this code for my project (the 8x8 LED RGB Matrix) but this function seems not to work. I can't recognise the mistake...
void Serial_Out (char nbytes, unsigned long value)   // nbytes = number of bytes to send; value = number to send
    for (unsigned long i=0; i<nbytes*8; i++)   // Repeats nbytes*8 times
        short a;
        a = 0!!(value & (1<<(nbytes*8-1)));     // Shifts bit-by-bit (on the PORTB) the value to send
        PORTB.F0 = a;
        PORTB.F1 = 1;                                // Raising edge of the SERIAL CLOCK
        PORTB.F1 = 0;                                // Falling edge of the SERIAL CLOCK -> now the bit has been shifted on the 74HC595 register
    PORTB.F2 = 1;                  // Raising edge of the LATCH CLOCK
    PORTB.F2 = 0;                  // Falling edge of the LATCH CLOCK -> now the 74HC595 outputs are "frozen" till the next LATCH CLOCK pulse comes
The errors are:
Invalid expression rgb_matrix_lib.h
; expected, but 'unsigned' found rgb_matrix_lib.h
; expected, but 'long' found rgb_matrix_lib.h
Undeclared identifier 'i' in expression rgb_matrix_lib.h
')' expected, but ';' found rgb_matrix_lib.h
'}' expected ';' found rgb_matrix_lib.h
; expected, but '.' found rgb_matrix_lib.h
'PORTB' Identifier redefined rgb_matrix_lib.h
Specifier needed rgb_matrix_lib.h
Invalid declarator expected'(' or identifier rgb_matrix_lib.h
Internal error '' rgb_matrix_lib.h
PS: this code belongs to an header (.h) file, which is going to be implement on the main code:
#include "RGB_Matrix_lib.h"
void main()
     ...CODE...
Feel free to ask me if I've not been clear. Thanks again for your help
This post has been edited by Mattyz on April 05, 2012 01:16 pm
Gorgon
Posted: April 06, 2012 12:43 pm
You are sure that the code in your header file, should not be in a .c file?
From the error messages you get I would think the precompiler does not like the taste of your .h file.
Definitions, references and prototypes in .h files, and this and code in .c files.
Light travels faster than sound. That's why some people appear bright until they speak!
Mattyz
Posted: April 11, 2012 06:19 pm
I studied better the meaning of .c files, .h files and so on and finally I solved my problem! Thank you for the input,
Matt
