| treez |
Posted: October 30, 2012 07:14 pm
Forum Addict ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 897 Member No.: 17,791 Joined: August 29, 2008 |
Hello,
I am trying to decide on NiCd or NiMH cells for use in an emergency LED lighting system....however, i cannot find comparitive pricing websites for different manufacturers batteries/cells.....also, digikey hardly lists any such batteries/cells. do you know of a website that i can use to compare different NiCd cell prices from different manufacturers.? |
Posted: October 31, 2012 06:48 pm
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 12,946 Member No.: 5,314 Joined: June 04, 2006 |
Wouldn't NiMH be a better choice than NiCd for a rarely used system?
I'm referring to the NiCd tendency to form "whiskers" (dendrites) and short themselves without sufficient current flow. -------------------- Mac *
Posted: October 31, 2012 11:16 pm
![]() Moderator Group: Moderators Posts: 8,895 Member No.: 62 Joined: July 23, 2002 |
NiCd is also banned in a lot of countries. Going NiCd will severely limit your markets.
-------------------- -= Gregg =-
| Colt45 |
Posted: November 01, 2012 07:40 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 3,747 Member No.: 1,333 Joined: October 02, 2004 |
Care to explain a bit better?
Will this be mobile or not? Will it be on charge all the time? How much power will be drawn when the system is running? etc..? NiMH is better than NiCd in most regards, but it has a fast self-discharge rate. Lead acid is pretty bad for this too... So either of those would have to be on trickle charge, or relatively frequent charging (once a month, say), or they'll be flat when you go to use them. There are low self discharge NiMH, though, which doesn't have that problem. If it's fixed, lead acid is going to be the cheapest. But it's big and heavy, so no good for mobile/small. Lithium is the best of them all, in almost all areas... but is a little more complicated to deal with. -------------------- >]:::|-
