| xavier |
Posted: November 13, 2012 11:30 pm
Jr. Member ![]() ![]() ![]() Group: Trusted Members Posts: 77 Member No.: 2,645 Joined: June 01, 2005 |
Can a logic level sensitive triac (such as MAC97A8) be controlled with a MOC3031 or similar triac driver? Or does it need to be lower voltage at the gate from an microcontroller?
Posted: November 14, 2012 01:26 am
![]() Forum Addict ++ Group: Moderators Posts: 18,142 Member No.: 73 Joined: July 24, 2002 |
Sure, you can get away with a much larger series current limiting resistor, perhaps 1kohm would be fine.
Tim -------------------- Answering questions is a tricky subject to practice. Not due to the difficulty of formulating or locating answers, but due to the human inability of asking the right questions; a skill that, were one to possess, would put them in the "answering" category.
| xavier |
Posted: November 14, 2012 09:30 pm
As always thank you for the reply!
| xavier |
Posted: December 06, 2012 06:07 am
I set this up and the MAC97A8 triac won't turn on. Is there a minimum load that must be there for the MAC97A8 to turn on? I'm trying to control a relay that has a 110vac coil. The coils rated current is 20ma and the coil resistance is 2360 ohms, coil power is 2VA
Posted: December 06, 2012 08:40 am
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 12,946 Member No.: 5,314 Joined: June 04, 2006 |
Not sure how familar you are with triacs, but here are a few of the basics.
- The main pins are called main terminal 1 (MT1) and main terminal 2 (MT2). There's also a gate drive pin. - The gate drive must be referenced to MT1 (i.e. driven from the MT2 side), and the load should always be placed on MT2 (not MT1). Placing a load on MT1 causes AC voltage to appear across the gate resistor and it will overheat. - The data sheet should specify gate trigger current (Igt). The gate requires a series resistor (value should be drive voltage divided by Igt + 20% to give it some margin). If resistance is too high, the TRIAC will not turn on or only turn on half the cycle. - The gate will trigger with a signal of either polarity. A negative gate signal (instead of positive with respect to MT1) requires less current. However, not all triacs respond well to a DC gate signal. - Gate current for a "sensitive gate" triac is usually under 20mA. - Once triggered, the device continues to conduct until the current through it drops below a certain threshold value (the holding current), such as at the end of a half-cycle of alternating current (AC) mains power. That's mostly from this page btw, with some other stuff thrown in. Hope it helps. -------------------- Mac *
