| ardudriver |
Posted: December 27, 2012 08:52 am
Newbie ![]() Group: Members+ Posts: 1 Member No.: 37,630 Joined: December 27, 2012 |
Hi all, I realized a toggle button using ne555, so everything is ok.
Now, I'd like to add the possibility to simulate pressing over digital signal from mcu. I thought to use a transistor (which should act as a switch) but it does not work, the circuit is correctly closed, but not 'clicks' as if it were closed by pressing the button. The problem is probably due to the logic of charging and discharging of the capacitor, here the two schematic before end after changes: schematic I noted that every time I press the button, the polarity of the two ends of the button are reversed and so I added a diode to avoid that the current flow over the transistor, this system would be fine only when the polarity of the terminals A and B (indicated in the schematic) were respectively + and -, and not the opposite. I would avoid for this solution to use a relay. I think that it is technically more interesting solve the problem by using a handful of components if possible, what do you think? New Happy Year to all. driver |
Posted: December 27, 2012 08:53 am
![]() Forum Addict ++ Group: Moderators Posts: 18,143 Member No.: 73 Joined: July 24, 2002 |
The link wants me to login to Yahoo AND create a Flickr account for some reason.
-------------------- Answering questions is a tricky subject to practice. Not due to the difficulty of formulating or locating answers, but due to the human inability of asking the right questions; a skill that, were one to possess, would put them in the "answering" category.
Posted: December 27, 2012 11:38 am
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 19,515 Member No.: 15,154 Joined: May 15, 2008 |
same thing here tim .
@ OP : upload the schematic to a place like photobucket and post the link . -------------------- "Know how to solve every problem that has been solved"
Posted: December 27, 2012 09:00 pm
![]() Moderator Group: Moderators Posts: 8,902 Member No.: 62 Joined: July 23, 2002 |
or imgur
-------------------- -= Gregg =-
