> Gpios States For Low Consumption
angelo
Posted: December 14, 2016 02:39 pm
i was wondering, when a cpu/mcu enters low consumption sleep mode, what could be the best pin configuration before sleep ? I am setting pins to hi-z. Maybe "input" is good too ?
Posted: December 15, 2016 01:31 am
Undefined pin states may float into the linear range where current consumption can be higher.
If the IO banks are physically powered down, this won't matter, but I don't know that that's something they ever do.
If you don't want to set a hard pin state, you can use soft pull-up or pull-down states, or external resistors. Whatever sets a well-defined voltage. smile.gif
angelo
Posted: December 15, 2016 10:55 am
Hi tim,
thanks,
no. in my case, gpio stages are not powered off, seems they can still keep the pre-set mode / level in power down mode.
Yes, quite all of the power control GPIOS control mosfets P gates (used as switch), and have external pullups, so setting them hi-z should work fine.
Best regards,
Angelo
David Stephenson
Posted: December 19, 2016 07:25 pm
I've found doing sleep power-downs the only way you can be sure is by actually measuring the current and checking against the datasheet.
I generally find there is something I've fogot to disable which is dragging current.
That said I never leave pins as input, but there again I never use pull-ups (except for internal ones) so it may work.
