| Fallingwater |
Posted: August 18, 2012 02:33 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 4,077 Member No.: 8,638 Joined: March 14, 2007 |
My motorcycle's gas tank pump seized, forcing me to drag the bike up a 2km incline to the nearest mechanic. Good thing it failed while the bike was parked and not on the go (had shown a tendency to lose acceleration shortly beforehand, but never died).
Mechanic says he'll try to fix it if it's repairable, otherwise I'll order a new one from the internets and replace it myself. I'm wondering though, what might have made it seize? The bike is five year old but has very little mileage on it, just 20k kilometres (been planning long trips every summer, and every summer fate conspires to keep me at home... grumble grumble). I'd like to know so I can avoid it in the future. -------------------- One man's trash is another man's treasure.
Learn the rules, so you can break them properly. |
Posted: August 18, 2012 04:16 pm
![]() Forum Addict ++ Group: Moderators Posts: 18,138 Member No.: 73 Joined: July 24, 2002 |
Dried out and siezed, old gas..?? Maybe a dash of lube would help (fuel stabilizer, kerosene, diesel fuel, 2 stroke oil, etc.?).
Tim -------------------- Answering questions is a tricky subject to practice. Not due to the difficulty of formulating or locating answers, but due to the human inability of asking the right questions; a skill that, were one to possess, would put them in the "answering" category.
Posted: August 18, 2012 04:54 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 9,978 Member No.: 2,735 Joined: June 21, 2005 |
Is your bike running on 2-stroke? If so then maybe you're not using the right mix ratio or, if the bike is stationary too long, the 2-stroke oil is settling out.
-------------------- May contain nuts
| Fallingwater |
Posted: August 18, 2012 04:57 pm
Four-stroke; tank only contains gas.
Hmm... I did occasionally leave it unused for days/weeks at a time with very little fuel in the tank. -------------------- One man's trash is another man's treasure.
Posted: August 18, 2012 05:04 pm
In-tank pump? or external?
Posted: August 18, 2012 09:05 pm
Heat.
If you're like one of those cheapasses who only puts 2 gallon in their car instead of fillling it up, then the pump isn't submerged and kept cool, so expect it to not last as long. |
| Fallingwater |
Posted: August 19, 2012 02:09 am
In-tank. -------------------- One man's trash is another man's treasure.
| dmg |
Posted: August 19, 2012 11:03 am
Sr. Member ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 279 Member No.: 36,860 Joined: June 06, 2012 |
as suggested keep the tank full.
and even if its four stroke, add a bit of 2 stroke oil. fuel with no oil has not so good lubrication. if you leave it parked for extended periods (like winter time) then allso fill the tank up. |
| draget |
Posted: August 19, 2012 12:17 pm
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Cleanup Taskforce Posts: 5,481 Member No.: 1,770 Joined: December 31, 2004 |
Fuel with too much oil will evaporate when you leave it for a long time and leave your fuel system all oily.
Posted: August 19, 2012 05:44 pm
Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 12,942 Member No.: 5,314 Joined: June 04, 2006 |
Not good. But sitting for weeks (or even a couple of months) with a half to full tank should pose no problems, assuming you'll use it up fairly soon afterward. However... if you only drive it occasionally and for short distances, there may come a point where gas in the tank is more old than new. If so, draining the tank every 4-5 months and refilling it with fresh fuel would be money well spent. It's also possible you just have a wonky fuel pump. Personally, I'd rather replace it than hire someone (of unknown skill) to attempt a repair, as a new one is more likely to prevent problems on the road. My two cents. -------------------- Mac *
Posted: August 20, 2012 10:50 am
![]() Moderator Group: Moderators Posts: 9,592 Member No.: 561 Joined: January 10, 2004 |
Fuel pump on a bike - that's just wrong
Of course in the good old days, bike wiring was pretty iffy and they tended to try to jamb everything they could in the headlight housing with lots of bullet connectors. Dunno if anything has gotten any better with the 21st century and electronics making it's way onto two wheelers, but I'd check to make sure the pump itself is the problem for sure. Also, is there a vacuum valve (to shut off fuel when the engine wasn't running) still used with the electronic pump? Seen a cracked hose or warped air box to carb seal cause starvation. -------------------- Hey! what's in here - is it a toy? oh. Hey! What's in here - is it a toy? oh.
| deth502 |
Posted: October 23, 2012 12:47 am
![]() Sr. Member ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 362 Member No.: 14,050 Joined: March 23, 2008 |
idk where your at, but here in the us, with the new regs making all fuel contain at least 15% ethanol is destroying a lot of recreational vehicles. especially boats and jetskis. even the cars its supposed to go in. many of the materials that are designed to contain the gasoline and not break down, do not fare as well with the ethanol.
Posted: October 23, 2012 02:16 am
I've heard much about this in recent years - including E85 compatibility and retrofits, but our pumps here in Ontario have had "may contain up to 15 percent ethanol" stickers for decades.
| draget |
Posted: October 23, 2012 03:40 am
Nothing in WA is ethanol blended
| Thunderbolt |
Posted: October 23, 2012 02:14 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 1,668 Member No.: 6,815 Joined: October 22, 2006 |
This. I've lost a fuel pump this way which wasn't a cheap fix. My excuse was that I'm a poor university student. -------------------- Good trades with: Skeith, Nothing40, Jimthecopierwrench. Want it!'s owing: Three.
| Jawno |
Posted: October 23, 2012 03:06 pm
Member ![]() ![]() ![]() ![]() Group: Trusted Members Posts: 101 Member No.: 34,329 Joined: January 20, 2011 |
Draget said: Nothing in WA is ethanol blended.
I'm not sure where WA is but if your talking Washington, as in the state, then you are sadly deluded. All gas here is ten percent blend. Check it out. Here in the US we are fighting aginst fifteen percent blend. It is supposed to cause excessive heat in air cooled engines. Supposedly the new pumps can deliver either ten or fifteen percent blends. The EPA (?) has sent notice that bike riders shouldn't put in less than four gallons of gas in case the person before you was putting in fifteen percent gas, it can take a bit for the mix to thin back down to ten percent. Rights organisations are fighting this as many motorcycle gas tanks are smaller than four gallons. My apologies for being off topic. I would agree, an in tank fuel pump should probably remain submerged to operate properly. |
| draget |
Posted: October 23, 2012 03:12 pm
I'm in Western Australia
aka : BFE |
| Skeith |
Posted: October 23, 2012 10:23 pm
![]() Forum Addict ++ ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Spamminator Taskforce Posts: 4,094 Member No.: 2,695 Joined: June 13, 2005 |
the in tank pumps use the fuel as a source of cooling and lubrication.
An improper blend or getting moisture in the pump can cause issues. Also running them dry can cause excessive wear and overheating. the bit of 2-stroke oil might be something to look into as mentioned earlier. Just don't add too much. Also some fuel stabilizers have additives designed to help lubricate the system -------------------- -Barrett
