> Matlab Iir Filter Design
kingneb
Posted: August 03, 2014 11:29 pm
I am using Matlab's fdatool to compute the coefficients for a filter I plan on running as an algorithm in a PC program I will write.
The standard formula for computing IIR is here:
http://en.wikipedia.org/wiki/Infinite_impulse_response
Matlab spits out the numerator coefficients, denominator coefficients, and groups them into filter sections. How does this categorization translate into the standard IIR equation?
Remember to take your records off the turntable when you are done listening to them, otherwise they will warp.
Posted: August 04, 2014 04:09 am
I believe you're looking at the x[n - i] being the input (numerator) coefficients, and y[n - j] being the denominator (feedback) coefficients.
Check out a textbook for more info (Wikipedia tends to be rather... unavailable, as far as teaching those outside the field goes).
CoulombMagician
Posted: August 09, 2014 05:29 pm
When you apply the z transform the delays all map to powers of z. Regroup the aj terms on the left side and then divide which moves them to the denominator on the right side. This leaves you with output = input * Num(z)/Denom(z).
To implement the filter you have to factor the rational function into biquadratic sections which can be realized. It sounds like you will be using floating point variables( PC software implementation) so you probably don't need to check the dynamic range between each of the sections. If you were implementing a fixed point hardware filter you would want to verify dynamic range in simulation.
On a practical level I believe that MatLab will spit out a C source code implememntation for you, that might save you some work.
